14 years agoError when uploading the code to the FPGA DE2-70
Hi all, I have followed the example you may find in tut_sopc_introduction_verilog.pdf Everything goes fine to the point where I need to upload the program... Then I get the following ...
14 years agoThank you for your help,
I have used a _time_limited.sof file, for the clock i used clk_0 with a 50 Mhz frequency, i don't know if it works well or not. Also, i have used the inport assignmets with the file "DE2_70_assignments.csv", Thank you
