14 years agoError when uploading the code to the FPGA DE2-70
Hi all, I have followed the example you may find in tut_sopc_introduction_verilog.pdf Everything goes fine to the point where I need to upload the program... Then I get the following ...
14 years agoWhen the CPU isn't responding, it can be either because the .sof file hasn't been loaded, it isn't the right .sof file, or one of the critical signals (clock, dada) isn't correct. Check all those points:[list][*]did the project compile successfully?[*]are you using the correct .sof file? If you are missing some licenses, the design could be compiled in a *_time_limited.sof file instead. Check the report[*]did you assign the ports to the correct FPGA pins? Especially reset and clock[*]is the clock running?[*]does the reset signal have the correct polarity. The reset_n pin from the SOPC builder project is active low[/list]
