11 years agoError: Unknown element arria10_part1
Hello all,
I have got a problem with Quartus II Web Edition 15.0 which I run on windows 8: I can't install any device file. I am talking about .qdz file. I need your help please. Thanks, Nick9 Replies
Yes, the 15.0.2 update will include the 15.0.1. By the way, have you try to contact Altera on this?
I am having the same problems as above with a new installation. I successfully installed Quartus II on a Windows 7, but when tried on a Windows 8.1, I get the Unknown element arria10_part1 Error. I can't find the file "quartusii-15.0.01we-windows.exe" mentioned above, Under “updates” tab or any other tab. I could only assume that the fix is now included in the “QuartusSetup-15.0.2.153-windows.exe” which I have already installed. Des anyone else have a suggestion? Thanks, - Altera_Forum
By the way, just wonder if you managed to try with the workaround mentioned by bfkstimchan at http://www.alteraforum.com/forum/showthread.php?t=48969?
I don't find the mentioned file in the mentioned area. Where can it be found? I'm stuck too and cannot use the Quartus II Web Edition tool.
For the update patch, you can look into http://dl.altera.com/15.0/?edition=subscription, look for "Updates" tab
Thanks to:
bfkstimchan an irish I can't find the patch : quartusii-15.0.01we-windows.exe - Altera_Forum
It seems to be Windows 8.1 bug.
You have to install a patch called "quartusii-15.0.01we-windows.exe" from Altera Tech Support. - Altera_Forum
Hi Nick,
Probably you could check this thread to see if it helps? http://www.alteraforum.com/forum/showthread.php?t=48969
