13 years ago
Error: Type conversion (to UNSIGNED) can not have string literal operand
Hai all,
I have run a testbench simulation in ModelSim and get this error:
# ** Error: bmp_generator.vhd(401): Type conversion (to UNSIGNED) can not have string literal operand.# ** Error: bmp_generator.vhd(401): VHDL Compiler exiting# ** Error: G:/modelsim(new)/modelsim_ase/win32aloem/vcom failed.
Why the error is come out even the code is from example in OpenCores? Anyone expert please helps :( Thanks in advance
    --- Quote Start ---
    what the different between bp<=SXT(a,9)+b with bp<=a+b? Or is it there are same actually? Can you give simple example for both line codes? Need helps,thanks in advance
    --- Quote End ---
    Both are invalid syntax.
    As commented in a previous thread in response to your question, SXT just extends the a signal by 1 bit.
    Rather than asking these questions, you should create a Modelsim simulation and try to figure it out yourself. You'll learn much better that way.
    Cheers,
    Dave
    --- Quote Start ---
    Neither is correct. If a, b, and bp are all std_logic_vector, then you cannot add without converting to signed or unsigned. std_logic_vector is just an array of bits, the compiler does not know how you want to interpret those bits, so you have to tell it using explicit casts/type-conversions.
    bp <= std_logic_vector(unsigned(a) + unsigned(b));
    where a and b are converted to unsigned, the sum a+b is also unsigned (1-bit wider), and it is converted to std_logic_vector before being assigned to bp (which is also std_logic_vector).
    Cheers,
    Dave
    --- Quote End ---
    Hai Dave,
    Then, what the different between bp<=SXT(a,9)+b with bp<=a+b? Or is it there are same actually? Can you give simple example for both line codes? Need helps,thanks in advance
    --- Quote Start ---
    I have another question, can you help me to verify it. I have line code of bp<=SXT(a,9) + b and bp<= a+b, wheres a and b is std_logic_vector(7 downto 0) and bp is std_logic_vector(8 downto 0). My question is what the different between the two line codes? thanks in advance
    --- Quote End ---
    Cheers,
    Dave
    --- Quote Start ---
    Change the line near the end to:
    DATA<= unsigned(DATAi)-UNSIGNED(std_logic_vector'(X"80")) when SIGNED_DATA=0 else DATAi;
    Note the change to enforce that the argument to UNSIGNED() is a std_logic_vector.
    Cheers,
    Dave
    --- Quote End ---
    Hai Dave,
    Thanks, its can simulate know..I have another question, can you help me to verify it. I have line code of bp<=SXT(a,9) + b and bp<= a+b, wheres a and b is std_logic_vector(7 downto 0) and bp is std_logic_vector(8 downto 0). My question is what the different between the two line codes? thanks in advance
    Cheers,
    Dave
