13 years ago
error sopc builder
hi
i have this error when i add my own component en verilog with an interface avalon
Error: rtp_tx_0.ram_master: ddr_sdram.s1 (0x0..0x1ffffff) is outside the master's address range (0x0..0xf)
thank you
    Hi
    can you tell me how can i define the component port as a maser in details
    thank you :)
    Your component exposes an Avalon master interface whose address port appears to be only 4 bit wide.
    So it can't definitely drive the 25bit address range of the sdram slave port.
    I think you are missing some point.
    Two guesses:
    - you defined the component port as a master, but it is actually a slave
    - you failed to export address lines
