13 years agoerror sopc builder
hi i have this error when i add my own component en verilog with an interface avalon Error: rtp_tx_0.ram_master: ddr_sdram.s1 (0x0..0x1ffffff) is outside the master's address range (...
13 years agoYour component exposes an Avalon master interface whose address port appears to be only 4 bit wide.
So it can't definitely drive the 25bit address range of the sdram slave port. I think you are missing some point. Two guesses: - you defined the component port as a master, but it is actually a slave - you failed to export address lines
