18 years agoError running quartus : Failed to start Core Services: Failed to launch rpcss
Hi all, I have a problem to run quartus on my linux, when I simply run it, I have a message like this : ./quartus
Abandon So I modified a little the run script to see where is the pr...
15 years ago --- Quote Start --- I forgot to paste the solution, now that I got this problem on a new machine, I am posting it here. The Fedora linux distro FC13 (11,12 too) by default puts machine name (abcd here) in /etc/hosts as first line 127.0.0.1 abcd.domain.com abcd localhost.localdomain localhost The line should be either 127.0.0.1 localhost.localdomain localhost or the line commented out altogether to get rid of this error. You all need machine ip in there. 192.168.1.xx abcd.domain.com abcd --- Quote End --- Thank you that solved my problem :) Details: I'm running Ubuntu 10.10, and installed Altera NiosII IDE and Quartus (both version 9.0) my /etc/hosts content was (when Quarts was giving "Segmentation fault"): 192.168.0.57 MirDesktop# Added by NetworkManager 127.0.0.1 localhost.localdomain localhost ::1 MirDesktop localhost6.localdomain6 localhost6 127.0.1.1 MirDesktop # The following lines are desirable for IPv6 capable hosts ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters When commenting row 3 and 4, everything works fine, my /etc/hosts looks now: 192.168.0.57 MirDesktop# Added by NetworkManager 127.0.0.1 localhost.localdomain localhost #::1 MirDesktop localhost6.localdomain6 localhost6 #127.0.1.1 MirDesktop # The following lines are desirable for IPv6 capable hosts ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters Hope this will help someone :) Thank you
