error running emif example design.
Hi Sandy,
There is typo in my previous reply. I have simulated the design in Modelsim 2021.1 not 2021.2. Sorry for that.
The path should be applicable for ModelSim Intel FPGA.
Are you using ModelSim from Intel?
Is there any win32aloem folder inside the Modelsim installation directory?
It's should be located at same directory of gcc-4.5.0-mingw64vc12 folder.
If yes, can you check the environment variable for that win32aloem path?
Adzim
we do not have 2021.1 either. I will have to check if i can get it on my machine.
we have 2020.1 and 2021.3.
My entire team is using 2021.3.
I am attaching screen shot of contents of the directory that was created when we install 2021.3.
It does not have the folders you mentioned. it did not even come with "gcc-4.5.0-mingw64vc12".
I downloaded it and copied it to C:\modeltech64_2021.3\win64 as part of the debug step.
i checked install directory for 2020.1 and it does not also have the directories you mentioned.
please can you tell me how make modelsim 2021.3 work with quartus 22.3?
Snady
