CosmoKramer
3 years agoerror running emif example design.
I am trying to run emif example design using model sim and running into this error after "ld_debug" command.
# vlog -reportprogress 300 -sv C:/intelfpga_pro/22.3/quartus/eda/sim_lib/simsf_dpi.cp...
AdzimZM_Altera
3 years agoHi Sandy,
Can you check C compiler path in the environment variable in your system?
- Go to Control Panel --> System & Security --> System --> Advanced system settings --> Environment Variables...
- Under User Variables, go to "Path" and click "Edit".
- Check that the following path is included: <modelsim installation path>\modelsim_ae\win32aloem
- If the path is missing, create a new path for that.
I have created an example design from Quartus version 22.3. And I have simulated with Modelsim 2021.2 and Questasim 2021.3.
But I don't see any error occurs during the simulation.
By any change, can you simulate the design with previous Modelsim version such as 2021.2?
Is it possible for you to provide the full error log and the design here?
Adzim
