CosmoKramer
3 years agoerror running emif example design.
I am trying to run emif example design using model sim and running into this error after "ld_debug" command.
# vlog -reportprogress 300 -sv C:/intelfpga_pro/22.3/quartus/eda/sim_lib/simsf_dpi.cp...
AdzimZM_Altera
3 years agoHi Sandy,
Can you check in the Modelsim installation for the "gcc-4.2.1-mingw32vc12" folder?
I would like to reproduce the issue at my side.
The example design was generated with Quartus version 22.3. Then the design was simulated with Modelsim 2021.3. Is it right?
Can you let me know which device that you used?
Thanks and Regards,
Adzim
