16 years ago
Error: quartus_map ended unexpectedly
Hi there,
I'm running Quartus II 10sp1 on ArchLinux. . When I'm trying to compile
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY my_and2 is
	PORT(A, B: IN STD_LOGIC;
		  C: OUT STD_LOGIC);
END my_and2;
ARCHITECTURE behav of my_and2 IS
BEGIN
			PROCESS(A, B)
			BEGIN
				C <= A AND B;
			END PROCESS;
END behav;
I've got this error
--- Quote Start ---
Error: Current module quartus_map ended unexpectedly
--- Quote End ---
Here is full log
--- Quote Start ---
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 10.0 Build 262 08/18/2010 Service Pack 1 SJ Web Edition
Info: Processing started: Tue Sep 21 18:00:11 2010
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off my_and2 -c my_and2
Info: Found 2 design units, including 1 entities, in source file my_and2.vhd
Info: Found design unit 1: my_and2-behav
Info: Found entity 1: my_and2
Info: Elaborating entity "my_and2" for the top level hierarchy
--- Quote End ---
Do you have any suggestions how to fix this error?
    I tried to execute quartus_map manually and received following
    --- Quote Start ---
    Error: Family name "Stratix II" is illegal
    Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
    Error: Peak virtual memory: 222 megabytes
    Error: Processing ended: Tue Sep 21 18:34:11 2010
    Error: Elapsed time: 00:00:01
    Error: Total CPU time (on all processors): 00:00:00
    --- Quote End ---
    My project should use Cyclone II, so I really puzzled but I remember setting Cyclone II device support. Might I have wrong config files?
