9 years agoerror of PCIE PERST_N whe running fitter!
Error (169029): Pin PERST_N is incompatible with I/O bank 3B. Pin uses I/O standard 2.5 V, which has a VCCIO requirement incompatible with that bank's VCCIO setting or its other pins that use VCCIO ...
9 years agoIf this is a board you've designed then you are out of luck - you should have test compiled your pin assignments before getting the board made.
If it is a dev kit then whoever designed the dev kit did a terrible job. You can't put pins that require 1.5V VCCIO on the same bank as pins that require 2.5V/3V VCCIO, and there is no work around as far as I'm aware.
