9 years agoerror of PCIE PERST_N whe running fitter!
Error (169029): Pin PERST_N is incompatible with I/O bank 3B. Pin uses I/O standard 2.5 V, which has a VCCIO requirement incompatible with that bank's VCCIO setting or its other pins that use VCCIO ...
9 years agoChange the pins I/O standard to one compatible with the VCCIO level on that bank, or move the pin to another bank with a compatible VCCIO level.
