14 years ago
error occurs when i changed my FPGA
first, i used the Cyclone, my program ran correctly.
then, i changed it to Cyclone IV, then the error occurs.
some controlling order in my program is wrong, i have not changed my program.
so , what's the matter?
someone can help me?
    From Cyclone to Cyclone IV there are differences in the PLLs, the memory components, some I/O features, timing and of course the pins. All of those can cause errors.
    --- Quote Start ---
    Yes, the first thing I would check is the pin assignments.
    --- Quote End ---
    i changed, of course.
    the problem is solved!!!
    i changed my program in some details.
    the error occurs in one of a state machines, but i can't talk it more detailed because of keeping secrets for my boss.
    i still don't know there are differences when the same program runs in different FPGAs. can you give me some advice?
    --- Quote Start ---
    when you changed the device, there should be a warning saying that your pin assignments will be gone.
    --- Quote End ---
    --- Quote Start ---
    of course. Cyclone (I) and Cyclone IV are different devices (obviously).
    --- Quote End ---
    i konw, but i changed the setup(device) in Quartus. So, the program should ran correctly.(i have tested an easy demo, and it run correctly in Cyclone IV)
    --- Quote Start ---
    what error?
    --- Quote End ---
    My program control different periphery devices, such as valves, stepmotors.
    when i changed my FPGA, the control signals are not correct, so these periphery devices can't work Normally.
