14 years agoError: Input port must be driven by a non-inverted input pin or another PLL
Hi,everyone.
I used a PLL to generate the special clock,after coplilation,an error occured:Error: Clock input port inclk[0] of PLL "d5m_pll" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block. The code listed: sys_pll d5m_pll( .areset(1'b0), .inclk0(OSC_50_BANK2_in), .c0(), .c2(D5M_XCLKIN),//24M .locked() ); OSC_50_BANK2_in is a clock source. Please tell me how the problem occured and how to solve it,thank you very much。3 Replies
You are right.I didn't assign to the clock.Thank you very much.
Thank you,I will check again.
I'm guessing OSC_50_BANK2_in is assigned to a pin that isn't a dedicated clock input location. Look in the Pin Planner.
