9 years agoError in linking SOPC buider system file with eclipse
Hello, I have successfully generated a system in SOPC builder but when I open eclipse to program Nios II processor present in SOPC design following error prompts "SOPC Builder system file does ...
9 years agoI'm a little confused. You mention SOPC Builder (which is ancient and deprecated) and it looks like you are using Quartus 9.0 for some reason. But the path you posted mentions Qsys, which is what you should be using. What device are you targeting and what edition of Quartus are you using? Also, if you are using anything other than the economy version of Nios, you need a separate license line.
