13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :)
I'll try to post as much relevant information as possible, so the next one who has this problem might get off a bit easier. "Error (209014): CONF_DONE failed to go high in device 1" The error message happens both when trying to program the Serial Flash Loader and when trying to program JTAG directly. The programming fails before there is any progress, it doesn't even say 0%. Auto Detect Device functions as it should though. I get the choice between EP4CE15 and EP3C16, but that has never been a problem with other designs. I have made a custom board with a FBGA256 Cyclone IV EP4CE15 fpga and some peripherals. The fpga is hooked up with JTAG for Serial Flash Loader (SFL) as described in the Device Handbook on page 218 (figure 8-29, revision november 2011). I'm using a 20MHz CMOS oscillator, although that shouldn't have any impact on this issue as far as I know. The supply voltages are derived through separate low-noise, high PSRR LDO-regulators which can deliver max 150mA each. They are connected as such: VCCIO of all IO-bank is 3,3V. VCCINT and VCCD_PLL is 1,2V. VCCA is 2,5V nCE (J3) is connected to ground. nStatus (F4), nConfig (H5) and CONF_DONE (H14) are all pulled to VCCIO by 10k resistors. MSEL are connected as MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=GND. But since I'm using JTAG these would be overridden anyways. The JTAG plug is connected as such: 1 - TCK (pin H3), pulled to GND by 1k 2 - GND 3 - TDO (pin J4) 4 - 2,5V 5 - TMS (pin J5), pulled to VCCIO by 10k.# modded this to VCCA. 6, 7,8 - N.C. 9 - TDI (pin H4), pulled to VCCIO by 10k.# modded this to VCCA. 10 - GND Does anyone know anything I can try?37 Replies
--- Quote Start --- The default is to connect all unused Pins to GND - it might anyhow be the better solution to use the "tri-state" option... --- Quote End --- I agree, but that's after the fpga is configured. Since I can't get it to start the configuration it shouldn't matter what I choose. I did try it now anyways, just in case. It did not help. - Altera_Forum
I have checked the lines, yes. They look fine.
Yes, I have thought about that the pins could have been connected to GND. As far as I have understood they are all tri-stated until configuration is done, since the default value is set in software..? - Altera_Forum
Well, based on "engineering judgement" and experience... If one combination exists preventing operation even with JTAG, you've hit it... (other might call it "Murphy's law"...)
Nevertheless - if the JTAG chain is valid (as the Device is detected in Programmer window / JTAG chain check completes) there might be something else... Have you checked the power lines are all avaliable (VCCINT, VCCPLL and VCCIO) and stable during and with end of JTAG datatransfer? Perhaps there are some pins connected by the FPGA (as being the default for unused ones) to GND that are low ohmic connected to VCCIO on your board... Otherwise I'm running out of ideas :-/ - Altera_Forum
--- Quote Start --- Uuups. My fault, indeed.. Sorry for that irritation. While this MSEL stuff will require a modification of PCB anyway, I'm wondering what prevents JTAG operation... Especially as "The JTAG configuration is always available, regardless of MSEL pin selection.". --- Quote End --- Maybe I've hit upon a magic MSEL-combination which prevents usage? That would be a bit funny I guess. - Altera_Forum
While this MSEL stuff will require a modification of PCB anyway, I'm wondering what prevents JTAG operation... Especially as "The JTAG configuration is always available, regardless of MSEL pin selection.". - Altera_Forum
--- Quote Start --- Hi, according to my datasheet (which might be not the most recent) the combination MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=GND is defined as Active Serial, Standard. (my configuration is MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=2,5V, i.e. Active Serial fast...). As this is just the frequency of DCLK I would assume this not being anything to worry (except you need "fast mode")... --- Quote End --- Are you sure you're not looking at the combinations for Cyclone IV GX? In my datasheet those combinations are in the table for GX, while the combination you are using is actually the same for both. --- Quote Start --- Maybe you should use a DMM and measure the resistance of CONF_Done to GND (w/o board powered) - maybe there is a "hard short"? --- Quote End --- It's a cool 2kOhm so that shouldn't pose a problem. - Altera_Forum
according to my datasheet (which might be not the most recent) the combination MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=GND is defined as Active Serial, Standard. (my configuration is MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=2,5V, i.e. Active Serial fast...). As this is just the frequency of DCLK I would assume this not being anything to worry (except you need "fast mode")... Maybe you should use a DMM and measure the resistance of CONF_Done to GND (w/o board powered) - maybe there is a "hard short"? - Altera_Forum
--- Quote Start --- Ok, one final.. Have you already configured other boards with the PC you are using at the moment? (just to be 100% sure it's not some USB-Blaster driver issue as often mentioned for 64Bit OS (Win7 or even XP)). --- Quote End --- I've tried two different pc's and two different usb-blasters. I had a computer specific problem when programming a Max V a while back, where the usb-blaster would work on Cyclone IV boards, Cyclone III and Max II. Just not Max V. It turned out to be a driver issue so it was the first thing I checked actually. :) It's bad news really, since I've tried everything hw-related that I can think of. Unfortunately I've connected the MSEL-pins in an invalid combination so I cannot hack on a provisional Active Serial either. Seems like I might just have to make a new pcb design and hope for the best I guess. I'm running out of ideas. - Altera_Forum
Ok, one final..
