13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :) I'll try to post as much relevant information ...
13 years ago --- Quote Start --- Hi, according to my datasheet (which might be not the most recent) the combination MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=GND is defined as Active Serial, Standard. (my configuration is MSEL0(H13)=2,5V, MSEL1(H12)=GND, MSEL2(G12)=2,5V, i.e. Active Serial fast...). As this is just the frequency of DCLK I would assume this not being anything to worry (except you need "fast mode")... --- Quote End --- Are you sure you're not looking at the combinations for Cyclone IV GX? In my datasheet those combinations are in the table for GX, while the combination you are using is actually the same for both. --- Quote Start --- Maybe you should use a DMM and measure the resistance of CONF_Done to GND (w/o board powered) - maybe there is a "hard short"? --- Quote End --- It's a cool 2kOhm so that shouldn't pose a problem.
