13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :) I'll try to post as much relevant information ...
13 years ago --- Quote Start --- Ok, one final.. Have you already configured other boards with the PC you are using at the moment? (just to be 100% sure it's not some USB-Blaster driver issue as often mentioned for 64Bit OS (Win7 or even XP)). --- Quote End --- I've tried two different pc's and two different usb-blasters. I had a computer specific problem when programming a Max V a while back, where the usb-blaster would work on Cyclone IV boards, Cyclone III and Max II. Just not Max V. It turned out to be a driver issue so it was the first thing I checked actually. :) It's bad news really, since I've tried everything hw-related that I can think of. Unfortunately I've connected the MSEL-pins in an invalid combination so I cannot hack on a provisional Active Serial either. Seems like I might just have to make a new pcb design and hope for the best I guess. I'm running out of ideas.
