16 years ago
"Error code" in Flash Programmer
Hi all,
I'm working with the Cyclone III development kit and with the NIOS. I'm trying to drive the parallel flash device: when I start the Flash Programmer it generates this errror :
Error code: 4 for comand: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/.../.../flash/test_NIOS_cfi_flash.flash" --base=0x1000000 --device =1 --instance=0' --cable=USB-Blaster [USB-0]' --program --verbose.
Is there any solution?
angelo
    --- Quote Start ---
    Hi all,
    angelo
    --- Quote End ---
    Have you solved this problem? I am encountering this trouble. The project can be loaded in another PCB board. I was disturbed several days. If you have got answer. Could you give me some guidance? Thanks a lot!
    The code C is very very simple: I'm working with the template "Hello World"
    If the code is not very long , I suggest you'd better attach the c code, otherwise it's hard to find the problem . Because Nios compiler is not very clear for the Question location.
