16 years ago"Error code" in Flash Programmer
Hi all, I'm working with the Cyclone III development kit and with the NIOS. I'm trying to drive the parallel flash device: when I start the Flash Programmer it generates this errror : Error c...
14 years ago --- Quote Start --- Hi all, I'm working with the Cyclone III development kit and with the NIOS. I'm trying to drive the parallel flash device: when I start the Flash Programmer it generates this errror : Error code: 4 for comand: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/.../.../flash/test_NIOS_cfi_flash.flash" --base=0x1000000 --device =1 --instance=0' --cable=USB-Blaster [USB-0]' --program --verbose. Is there any solution? Thanks angelo --- Quote End --- Hi, Have you solved this problem? I am encountering this trouble. The project can be loaded in another PCB board. I was disturbed several days. If you have got answer. Could you give me some guidance? Thanks a lot!
