14 years agoerror: can't place multiple pins assigned to pin location
In Pin planner, i run "start i/o pin analysis"(compile), and i receive an error "error: can't place multiple pins assigned to pin location" but on the list, there I only assigned 1 "node name" to th...
14 years agoWhen you select a configuration scheme, Quartus automatically and transparently assigns the pins. In your case, it's the 4 signals needed by Active Serial configuration.
If you want to access the EPCS for other things than configuration, there's a special feature. In any case, you don't even need to have those 4 signals in your top level module. Unless you want to connect custom logic to the AS interface pins -- not sure if it's even possible.
