Error (209053): Unexpected error in JTAG server -- error code 38
I'm dealing with an issue trying to program the EPM570F100 with a USB blaster and with Quartus Prime Programmer Version 17.1.0 but even the JTAG chain is executed successfully:
Chain Continuity Checker
Chain Continuity during IR is not stuck at zero or one
Chain Length -- Load IR of all ones then count DR length
Number of Devices is 2
IR Length Calculator
Instruction Register Length is 16
IDCODE Reader
TDO -> TDI | Rev Device Mfgr 1 | ID (HEX) |
Device #1 | 0000 0010 0000 1010 0010 0000 1101 110 1 | 020A20DD |
Device #2 | 0010 0011 0111 0101 0001 0000 1001 001 1 | 23751093 |
Device Identifier -- Search for device name from list of device IDCODE values
TDO -> TDI | Device Mfgr |
Device #1 | EPM570 Altera |
Device #2 | Unknown IDCODE |
Exit code = 0... Success
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
the following errors appears:
Info: Processing started: Thu Jul 20 16:10:51 2023
Info: Command: quartus_pgm -c 1 file1.cdf
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file file2.pof with checksum 0x002C5D97 for device EPM570F100@2
Info (209060): Started Programmer operation at Thu Jul 20 16:10:51 2023
Error (209053): Unexpected error in JTAG server -- error code 44
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Thu Jul 20 16:10:52 2023
Error: Quartus Prime Programmer was unsuccessful. 3 errors, 1 warning
Any advise? Already tried different USB blaster and device
- RaulEstrada
Not resolved yet. I was on vacations and even I have tried suggestions provided before no changes. I will verify this week other suggestions provided by my technical coworkers and let it know if any progress, keep posted.
- WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
- WZ2
Hi there,
Is it solved~
- WZ2
I see you do some debug on this issue. The reason of device, usb line and the JTAG chain's transfer work well. There are some advice I can see:
- Make sure the device work well and there is no voltage drop during the configuration.
- Try to use other easy sof to do the program, and use programmer to do the test.
- Although you already change the device, I still suggest to kill the process of jtaged and try again.
WZ
- WZ2
Hi there,
To solve this issue, there are some points I need to make clear:
- Do you use the Altera's USB-Blaster II?
- What system u used? Windows or Linux?
WZ
- RaulEstrada
Hi WZ2,
I'm using old version USB-Blaster (not version II) and using windows 10.
Note the driver for this is ok and working correctly according device manager.
Raul
