Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system.
I am having the problem above, my board is the DE10 Standard and I am following all the steps on chapter 8.3 of the user manual.
When I program the cyclone V with a SOF file, it does work. I couldn't find a good explain of MSEL DIP in any manual also.
Would you please help me?
Thanks in advance.
- AnandRaj_S_Intel
Hi NMene,
Can you please check your MSEL again.
Set MSEL[4..0] = “10010”
It should be like.
SW10.1 MSEL0 ON (“0”)
SW10.2 MSEL1 OFF (“1”)
SW10.3 MSEL2 ON (“0”)
SW10.4 MSEL3 ON (“0”)
SW10.5 MSEL4 OFF (“1”)
SW10.6 N/A N/A
Reference table 7-2.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
Anand Raj Shankar
- NMene
Ok, Now everything is working fine. Thank you very much. Nilton Gaviao Menezes. Em dom, 17 de fev de 2019 às 22:32, Intel Forums <[email protected]> escreveu:
