9 years agoError (169175): Pin # with LVDS I/O standard needs a differential output?
Hi, I'm using a Terasic DE10-lite board with a 10M50DAF484C7G MAX 10. I'm trying to use some LVDS differential outputs but I get this error: Error (169175): Pin "GPIO" with LVDS I/O standar...
9 years ago --- Quote Start --- Hi irishling, thanks for the reply. I've tried what you suggest but I continue to receive the same errors. I tried configuring the pins in 3 different ways as you see from this pictures (https://imgur.com/a/l2vjy), but no one has worked. What can you suggest me? --- Quote End --- Hi, the attached picture is not clear for viewing. For LVDS output, you need to ensure you are assigning the LVDS output yo DIFFIO_TX_RX but not the DIFFIO_RX. For example: pin_W13 is the DIFFIO_RX_B35p which is not supported for the LVDS ouput. I believe the error message should be eliminated once you change the pin location to the DIFFIO_TX_RX such as Pin_P11 (DIFFIO_TX_RX_B20p). You may get the Dedicated Tx/Rx Channel pin definition from its pin out file: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/max-10/10m50da.pdf Best Regards, irishling (This message was posted on behalf of Intel Corporation)
