9 years agoError (169175): Pin # with LVDS I/O standard needs a differential output?
Hi, I'm using a Terasic DE10-lite board with a 10M50DAF484C7G MAX 10. I'm trying to use some LVDS differential outputs but I get this error: Error (169175): Pin "GPIO" with LVDS I/O standar...
9 years ago --- Quote Start --- I tried configuring the pins in 3 different ways as you see from this pictures. --- Quote End --- Unfortunately we don't see anything from these pictures because the resolution is too low. It's a typical problem when posting *.jpg images in the forum, you should always verify that they are readable. I see in the pinout table that the said pins are DIFFIO_RX rather than DIFFIO_TX_RX pin pairs. Means you can assign an LVDS input or an emulated LVDS_E_3R standard to it, but not a LVDS output standard. Review the MAX10 pin connection guide line document for details.
