8 years agoError (114016): Out of memory in module quartus_fit.exe
i compile my project today,quartus 13.0sp1 32bit show me a error:"Error (114016): Out of memory in module quartus_fit.exe (399 megabytes used)" the device i used is EP3C16Q240C8 my computer cofi...
8 years agoHi Jay,
"170048 selected device has 128 RAM location(s) of type M9K. However, the current design needs more than 126 to successfully fit" 1.The Error message is due to insufficient memory in EP3C16Q240C8. 2. EP3C16 device support only (56 M9K block and total of 516,096 i.e =56*1024*9(m9k block x depth × width including sign bit) 516096 bits. 3. So can't use more that 516096 bits. For more information check https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyc3/cyc3_ciii51001.pdf Yes the quartus_fit.exe error is related to the PC memory management issues. Close the background task and run. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
