14 years agoError (10686) Aggregate value
Hi, I am trying to use a reduction operator on a wire to check for zero. I used to do this all the time using model sim, but now it seems there is some problem with using any reduction operato...
14 years agoNot sure if this will fix your error, but I see one issues:
Change your always block from: // control logic block always @ ( Ctrl, A, B ) begin ... to // control logic block always @ ( * ) begin Your sensitivity list is incomplete, and can cause differences between synthesis and simulation..
