13 years agoerror : cant" resolve multiple constatn driver for...
Hi. I am making digital clock, and I have problem..
When i insert the red letters, errors rise. ( when I remove the red letters, errors is removed. error : Error (10028): Can't resolve multiple constant drivers for net "hour_2p[x]" at counter_test01.vhd Error (10028): Can't resolve multiple constant drivers for net "minute_2p[x]" at counter_test01.vhd Error (10028): Can't resolve multiple constant drivers for net "second_2p[x]" at counter_test01.vhd what does " cant't resolve multiple constant drivers for net ~ " mean? How can I remove the errors? LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY counter_test01 is port( button0 : in std_logic; -- mode_change button2 : in std_logic; -- time_select_up_key, and select_key button1 : in std_logic; -- time_select_down_key sw9 : in std_logic; -- select_key seven_seg0 : out std_logic_vector (7 downto 0); seven_seg1 : out std_logic_vector (7 downto 0); hour_2p : out std_logic_vector(5 downto 0); -- hour minute_2p : out std_logic_vector(5 downto 0); -- minute second_2p : out std_logic_vector(5 downto 0); -- second rst_n : buffer std_logic; --active_low_reset clk : in std_Logic); --clock_pulse end counter_test01; ARCHITECTURE arc of counter_test01 is signal clock_count : std_logic_vector(3 downto 0); signal second_pulse : std_logic; signal minute_pulse: std_logic; signal second_count : std_Logic_vector(5 downto 0); signal minute_count : std_logic_vector(5 downto 0); signal hour_count : std_logic_vector(5 downto 0); signal button0_sg : std_logic_vector(2 downto 0); signal button1_sg : std_logic; signal button2_sg : std_Logic; constant clock_cnt : integer := 9; -- 10Hz to 1Hz constant second_cnt : integer := 59; constant minute_cnt : integer := 59; constant hour_cnt : integer := 23; constant zero : integer :=0; constant six : integer :=6; begin process(rst_n,button0,sw9) begin if(rst_n ='0') then button0_sg <= (others =>'0'); button1_sg <= '0'; button2_sg <= '0'; elsif(button0'event and button0 = '1') then if(button0_sg < six) then button0_sg <= button0_sg + 1; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then clock_count <= (others =>'0'); second_pulse <= '0'; elsif(clk'event and clk ='1') then if clock_count < clock_cnt then clock_count<= clock_count + 1; else clock_count<= (others => '0'); end if; if clock_count = clock_cnt then second_pulse <='1'; else second_pulse <= '0'; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then second_count <= (others => '0'); minute_pulse <= '0'; second_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_pulse = '1') then if second_count < second_cnt then second_count <= second_count + 1; else second_count <= (others => '0'); end if; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then minute_count <= (others => '0'); minute_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_count = second_cnt and second_pulse = '1') then if minute_count < minute_cnt then minute_count <= minute_count + 1; else minute_count <= (others => '0'); end if; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then hour_count <= (others => '0'); hour_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_pulse = '1' and second_count = second_cnt and minute_count= minute_cnt) then if hour_count < hour_cnt then hour_count <= hour_count + 1; else hour_count <= (others => '0'); end if; if hour_count = hour_cnt then rst_n<= '0'; end if; end if; end if; end process; ------------------------------------------------------------- ------------------------------------------------------------- time 24LIBRARY IEEE; process(rst_n) begin if(button0_sg = "000") then second_2p <= second_count; minute_2p <= minute_count; hour_2p <= hour_count; end if; end process; end arc;2 Replies
And to complete kaz' answer, "cant't resolve multiple constant drivers for net" means that you are assigning a value to the same signal in different places, either from several processes (which is the case here), from several concurrent statements in the architecture, or a combination of both. While this is valid in VHDL, it isn't synthesizable.
I can see your hour_2p, minute_2p ... also assigned in reset of previous process. So just remove them from there and reset them in their last process.
