17 years agoerror -- Flash & NIOS2
Hello to all, i built a stand alone electronics with an EP2C8 fpga and an 2MB flash-ram. I flashed my EPCS4 device with my current design. By the way, i purchased a license for MegaCore functio...
17 years agoNo, I have done nothing after the generation. I think, I solved this problem...
At the first time I would flash the eeprom with the nios2 programm, but it doesn't work. ID error etc., because the jtag connection to my fpga had a fault. I realized it than I tried to flash the nios2 programm in the on_chip memory. I got the same ID and timestamp error as before. This morning I found the mistake and now it works. But could you tell me what a cfi table is ? #!/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd C:/Programm_ARCUS-OBITER_Handheld/software/hello_world_small_0/Release # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00200000 --end=0x3fffff --reset=0x40400 0 --input="hello_world_small_0.elf" --output="cfi_flash.flash" --boot="C:/altera /81/ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00200000 --cable='USB-Blas ter [USB-0]' --device=1 --sidp=0x00409030 --id=1732617863 --timestamp=1246886060 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00409030: verified <--- jipiiiie No CFI table found at address 0x00200000 Leaving target processor paused
