17 years agoerror -- Flash & NIOS2
Hello to all, i built a stand alone electronics with an EP2C8 fpga and an 2MB flash-ram. I flashed my EPCS4 device with my current design. By the way, i purchased a license for MegaCore functio...
17 years agoI assume that you took the PIC1 picture before you generated the SOPC system? If yes you need to take it after. The timestamp is changed each time you generate the system. If you look at it after the generation you should see the same value everywhere.
