17 years agoerror -- Flash & NIOS2
Hello to all, i built a stand alone electronics with an EP2C8 fpga and an 2MB flash-ram. I flashed my EPCS4 device with my current design. By the way, i purchased a license for MegaCore functio...
17 years agoAre you using the NIOS II IDE to program the flash? If so, it should be getting these values automatically from your PTF file. So if it's not, then you have a problem. I'd check to make absolutely sure your system library and software project are pointing to the right PTF file.
Jake
