mythic
3 years agoEPM7064STC-100 error with USB-blasterII
I'm using Quartus II 13.0SP1, I tried to program the device and i'm having an error. When I use a cheap USBblaster , it pass the jtag chain debugger and I can program the device no problem, bu...
mythic
3 years agoHello Aiman,
-Can you use the later Quartus version? such as version 20.1?
* Does is support MAX7000S devices?
-Can you delete and reinstall the USB blaster driver? Make sure the driver are install correctly.
* I already tried, even with a fresh Quartus install, no luck. Drivers install correctly, no error,no warning.
-Do you have another genuine USB Blaster to test?
* Those programmer are pricey, and i only own one, which is brand new.
thanks,
Marc
