11 years agoEPCS64 boot configuration
Hi, I working into the DE2-115 board. I want to save the Nios II program into the EPCS64 memory. (Save SOF content and ELF content into EPCS). I tried a lot of configuration that I have read in forum...
11 years agoHi, I added the next lines to the nios2-flash-override.txt file:
[EPCS-FF]# EPCS64N(lead-free) sector_size = 65536 sector_count = 128 Now I tried to erase all the EPCS memory, using the respective command, but took almost an hour for an EPCS64 memory: Now I am trying to program it with first the sof file converted to .flash: This is the output: $ nios2-flash-programmer --epcs --base=0x21400 hw.flash --debug Reading override file "C:/altera/14.0/nios2eds/bin/nios2-flash-override.txt" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Processor data bus width is 32 bits Looking for EPCS registers at address 0x00021400 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found EPCS signature is 0xFF EPCS device doesn't support RDID command Using EPCS size information from section [EPCS-FF] Device size is 8MByte (64Mbit) Erase regions are: offset 0: 128 x 64K EPCS status is 0xFF : Checksumming existing contents 00000000 : Verifying existing contents 00000000 : Needs erase then program 00010000 : Verifying existing contents 00010000 : Needs erase then program 00020000 : Verifying existing contents 00020000 : Needs erase then program 00030000 : Verifying existing contents 00030000 : Needs erase then program 00040000 : Verifying existing contents 00040000 : Needs erase then program 00050000 : Verifying existing contents 00050000 : Needs erase then program 00060000 : Verifying existing contents 00060000 : Needs erase then program 00070000 : Verifying existing contents 00070000 : Needs erase then program 00080000 : Verifying existing contents 00080000 : Needs erase then program 00090000 : Verifying existing contents 00090000 : Needs erase then program 000A0000 : Verifying existing contents 000A0000 : Needs erase then program 000B0000 : Verifying existing contents 000B0000 : Needs erase then program 000C0000 : Verifying existing contents 000C0000 : Needs erase then program 000D0000 : Verifying existing contents 000D0000 : Needs erase then program 000E0000 : Verifying existing contents 000E0000 : Needs erase then program 000F0000 : Verifying existing contents 000F0000 : Needs erase then program 00100000 : Verifying existing contents 00100000 : Needs erase then program 00000000 : Reading existing contents 00010000 : Reading existing contents 00020000 : Reading existing contents 00030000 : Reading existing contents 00040000 : Reading existing contents 00050000 : Reading existing contents 00060000 : Reading existing contents 00070000 : Reading existing contents 00080000 : Reading existing contents 00090000 : Reading existing contents 000A0000 : Reading existing contents 000B0000 : Reading existing contents 000C0000 : Reading existing contents 000D0000 : Reading existing contents 000E0000 : Reading existing contents 000F0000 : Reading existing contents 00100000 : Reading existing contents Checksummed/read 15kB in 510.3s 00000000 ( 0%): Erasing 00010000 ( 5%): Erasing 00020000 (11%): Erasing 00030000 (17%): Erasing 00040000 (23%): Erasing 00050000 (29%): Erasing 00060000 (35%): Erasing 00070000 (41%): Erasing 00080000 (47%): Erasing 00090000 (52%): Erasing 000A0000 (58%): Erasing I guess that the 0x400 offset is due the CycloneIV bootloader, which has 1024 bytes of content. I do not know why took a lot of time to program and erase the memory. Also in one opportunity I guess that the programming was frozen because never pass the 0%.
