11 years agoEPCS64 boot configuration
Hi, I working into the DE2-115 board. I want to save the Nios II program into the EPCS64 memory. (Save SOF content and ELF content into EPCS). I tried a lot of configuration that I have read in forum...
11 years agoIs your FPGA configured? Check the LED. If the FPGA isn't configured, use the programmer to load the sof file before using the nios2-flash-programmer command. Also, use the --mmu option if the nios processor you've chosen has an mmu in it regardless of if you are using the mmu or not.
