11 years ago
EPCS64 boot configuration
Hi, I working into the DE2-115 board. I want to save the Nios II program into the EPCS64 memory. (Save SOF content and ELF content into EPCS). I tried a lot of configuration that I have read in forums, etc. I am using Quartus II 64 bits web edition. The design is made in Qysys.
I have:
cpu with reset vector to EPCS controller (offset 0, then reset vector = base address of epcs controller=0x00021000).
cpu vector exception to onchip memory.
I have the jtag debug module properly connected (reset and data bus)
Nios CPU has a 50 Mhz ****, and the epcs controller has a clock of 20 Mhz (through altpll).
When I follow these steps:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd11192013_118.html
but I got an error when I tried to communicate with the EPCS device. (nios2-flash-programmer --epcs --base=0x00021000 hw.flash --debug)
I get this error:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Processor data bus width is 32 bits
Looking for EPCS registers at address 0x00021000 (with 32bit alignment)
Initial values: 00000000 00000000 6123D6C4 00000006 00000000 00000000
Not here: reserved fields are non-zero
Looking for EPCS registers at address 0x00021100 (with 32bit alignment)
Looking for EPCS registers at address 0x00021200 (with 32bit alignment)
Looking for EPCS registers at address 0x00021300 (with 32bit alignment)
Looking for EPCS registers at address 0x00021400 (with 32bit alignment)
No EPCS registers found: tried looking at addresses
0x00021000, 0x00021100, 0x00021200, 0x00021300 and 0x00021400
Leaving target processor paused
What it can be wrong? I cant figure out.
Thank!
    Hi Brad,
    I double checked the sector and sizes. Also I saw into the Terasic demonstrations folder, a folder called EPCS patch, which has the override file which this content:
    [EPCS-010216]# EPCS64N(lead-free)
    sector_size = 65536
    sector_count = 128
    [EPCS-012018]# EPCS128N(lead-free)
    sector_size = 262144
    sector_count = 64
    I put this content, and then the option with FF signature. The kit (DE2-115) has an original EPCS memory from Altera. It is weird, took like 5 hours I guess. But the previous log is not for an "erase-all" instruction, is for a programming image. However something is not working well.
    Hi frank2215,
    It looks like the programmer is performing the necessary tasks (erasing and programming). But it definitely should not take several hours to complete.
    Are you sure you put the correct entries for the sector_size and sector_count variables for your flash? I'm not sure how the programmer will behave if the values don't match the geometry of the flash.
    Also, according to your output log, it appears that the programmer thinks it erased 1088kB (~1.09 MB) of data instead of 8 MB. This also seems to be confirmed by the address range the programmer is accessing (0x0010,0000). The programmer should be accessing up to address 0x007F,FFFF (8 MB). You should probably take a closer look at that.
    Did the programming ever complete? If so, how long did it take?
    - Brad
    Actually it is not frozen, I run the program again and it seems that is working, but it started 3 hours ago...
    $ nios2-flash-programmer --epcs --base=0x21400 hw.flash --debug
    Reading override file "C:/altera/14.0/nios2eds/bin/nios2-flash-override.txt"
    Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
    Valid registers found
    EPCS signature is 0xFF
    EPCS device doesn't support RDID command
    Using EPCS size information from section [EPCS-FF]
    Device size is 8MByte (64Mbit)
    Erase regions are:
    offset 0: 128 x 64K
    EPCS status is 0xFF
    : Checksumming existing contents
    00000000 : Verifying existing contents
    00000000 : Needs erase then program
    00010000 : Verifying existing contents
    00010000 : Needs erase then program
    00020000 : Verifying existing contents
    00020000 : Needs erase then program
    00030000 : Verifying existing contents
    00030000 : Needs erase then program
    00040000 : Verifying existing contents
    00040000 : Needs erase then program
    00050000 : Verifying existing contents
    00050000 : Needs erase then program
    00060000 : Verifying existing contents
    00060000 : Needs erase then program
    00070000 : Verifying existing contents
    00070000 : Needs erase then program
    00080000 : Verifying existing contents
    00080000 : Needs erase then program
    00090000 : Verifying existing contents
    00090000 : Needs erase then program
    000A0000 : Verifying existing contents
    000A0000 : Needs erase then program
    000B0000 : Verifying existing contents
    000B0000 : Needs erase then program
    000C0000 : Verifying existing contents
    000C0000 : Needs erase then program
    000D0000 : Verifying existing contents
    000D0000 : Needs erase then program
    000E0000 : Verifying existing contents
    000E0000 : Needs erase then program
    000F0000 : Verifying existing contents
    000F0000 : Needs erase then program
    00100000 : Verifying existing contents
    00100000 : Needs erase then program
    00000000 : Reading existing contents
    00010000 : Reading existing contents
    00020000 : Reading existing contents
    00030000 : Reading existing contents
    00040000 : Reading existing contents
    00050000 : Reading existing contents
    00060000 : Reading existing contents
    00070000 : Reading existing contents
    00080000 : Reading existing contents
    00090000 : Reading existing contents
    000A0000 : Reading existing contents
    000B0000 : Reading existing contents
    000C0000 : Reading existing contents
    000D0000 : Reading existing contents
    000E0000 : Reading existing contents
    000F0000 : Reading existing contents
    00100000 : Reading existing contents
    Checksummed/read 15kB in 510.3s
    00000000 ( 0%): Erasing
    00010000 ( 5%): Erasing
    00020000 (11%): Erasing
    00030000 (17%): Erasing
    00040000 (23%): Erasing
    00050000 (29%): Erasing
    00060000 (35%): Erasing
    00070000 (41%): Erasing
    00080000 (47%): Erasing
    00090000 (52%): Erasing
    000A0000 (58%): Erasing
    000B0000 (64%): Erasing
    000C0000 (70%): Erasing
    000D0000 (76%): Erasing
    000E0000 (82%): Erasing
    000F0000 (88%): Erasing
    00100000 (94%): Erasing
    Erased 1088kB in 850.6s (1.2kB/s)
    00000000 ( 0%): Programming
    00010000 ( 5%): Programming
    00020000 (11%): Programming
    Hi, I added the next lines to the nios2-flash-override.txt file:
    [EPCS-FF]# EPCS64N(lead-free)
    sector_size = 65536
    sector_count = 128
    Now I tried to erase all the EPCS memory, using the respective command, but took almost an hour for an EPCS64 memory:
    Now I am trying to program it with first the sof file converted to .flash: This is the output:
    Erase regions are:
    offset 0: 128 x 64K
    EPCS status is 0xFF
    I guess that the 0x400 offset is due the CycloneIV bootloader, which has 1024 bytes of content. I do not know why took a lot of time to program and erase the memory. Also in one opportunity I guess that the programming was frozen because never pass the 0%.
    Hi frank2215,
    The fact that the nios2-flash-programmer found some valid registers @0x00021400 is a good sign.
    It appears that that the programmer can't read the ID of the flash IC being used in order to know it's geometry. When I ran into this problem with a 8 MB serial flash IC, the programmer told me I needed to create section [EPCS-010216].
    I ended up creating an override file ("nios2-flash-override.txt") and stored it on my system @ c:\altera\14.1\nioseds\bin.
    This override file contained the following:
    [EPCS-010216]
    sector_size - 65536
    sector_count = 128
    Once I did that, the nios2-flash-programmer recognized my device at the address for the valid registers (which was 0x400 in my case) and I was able to program it.
    It sounds like you device ID isn't recognized so you might have to create a section in the override file called [EPCS-FF] with he proper sector size and sector count values for your device. You should be able to find these values from the datasheet for your flash.
    Let us know if that helps or if you continue to run into other problems.
    - Brad
    I testet the epcs controller with 50 Mhz, (the same cpu freq) and does not work. Also tested with 20 mhz (altpll) and does not work as well.
    I tested exporting the epcs pins to the verilog top level, and I assigned to the pyshical epcs pins. Now I have something new. The FPGA is configured when I download the sof file, if I run the jtag command, I get:
    $ jtagconfig -n
    1) USB-Blaster [USB-0]
    020F70DD EP3C120/EP4CE115
    Node 19104600 Nios II# 0
    Node 0C006E00 JTAG UART# 0
    Design hash 6122D8B3ADF70138D8B4
    The processor is running, but if I try to ask for the EPCS I have the following:
    nios2-flash-programmer --epcs --base=0x00021000 --debug
    Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
    Initial values: 93000237 6300080C 603FFD26 90000335 A8000C26 03010004
    Initial values: 02C02004 002EE03A 00000F06 90000335 4000683A 0017883A
    Initial values: 003FD006 5280040C 501496FA 701CD07A 729CB03A 843FFFC4
    EPCS identifier and signature are all ones - please check for data stuck high
    No EPCS layout data - looking for section [EPCS-FF]
    Unable to use EPCS device
    I am not using MMU, actually I use the NIOS economyc version which do not have the MMU / MPU support.
    Is your FPGA configured? Check the LED. If the FPGA isn't configured, use the programmer to load the sof file before using the nios2-flash-programmer command. Also, use the --mmu option if the nios processor you've chosen has an mmu in it regardless of if you are using the mmu or not.
    Any reason you sent a different clock rate to the epcs controller in qsys? Try using the 50MHz for both NIOS and EPCS controller.
    --- Quote Start ---
    Hi frank2215,
    Is your Nios processor using an MMU? If so, you will need to add the --mmu switch to your nios2-flash-programmer command line: nios2-flash-programmer --epcs --mmu --base=0x000021000 hw.flash --debug
    If that doesn't work then are you sure that the Nios processor is even seeing the flash? Have you confirmed your base address is correct?
    Just my two cents.
    - Brad
    --- Quote End ---
    Brad,
    No, I am not using MMU, just a C application. I tested the EPCS64 downloading in other project a POF configuration and all works fine. I did nit try to write/read operatios. But I guess that the EPCS transactions are made by the FPGA, not the NIOS running any program. The base address is set right (0x00021000). Inmediately I download the SOF file, the leds power on in random fashion. It seems like the configuration is not working, these happens when the reset vector is set to EPCS controller base address.
    Hi frank2215,
    Just my two cents.
    - Brad
