16 years agoEPCS16 in AS Mode
hi, i cannot configure the EPCS16 in AS Mode with my appplication, i have downloaded the xxx.pof file with succes in my device but by reseting i can't see some effect i don't know where the ...
15 years agoThanks.
Yes, It has nothing to do with the external crystal as DCLK is supplied by internal 10M clock. The problem is exactly the same as described in the thread http://www.alteraforum.com/forum/showthread.php?t=26422 (http://www.alteraforum.com/forum/showthread.php?t=26422) Configuration is correct when I touch a scope probe on the DCLK. I have tried to connect a 1K resister or a 47nF capacitor between DCLK and GND, but it didn't contribute. I will look for other means to solve the problem instead of replacing the EPCS16 with EPCS4. I have tried to Disable AS mode CONF_DONE error check, but it doesn't matter.
