16 years agoEPCS16 in AS Mode
hi, i cannot configure the EPCS16 in AS Mode with my appplication, i have downloaded the xxx.pof file with succes in my device but by reseting i can't see some effect i don't know where the ...
15 years agoThanks for thepancake's opinion, I will try it right now.
And thank ammar as well. The interconnection between EPCS and FPGA are according to the handbook. The same schem works when I connect a EPCS4 with EP3C16Q240(Only the pin definition are different from EP3C25F324) in another board, so I don't think there are problems. MSEL[3:0] is constantly 0010. Maybe I should check the dclk timing, because I am using a 50M crystal which may be a little high. I will post my results later.
