APrab8
6 years agoEPCS16 device connected to a 10 pin programmer header in active serial as MTD device.
Hi Forum, I have an EPCS16 device connected to a 10 pin programming header from a raspberry pi. My target is to program a .pof file using active serial configuration to the EPCS16 device. what I ...
JohnT_Altera
6 years agoHi,
It will depend on your rasberry pi. In the Quartus Convert programming file (this is only available in latest Quartus version), you can go to Advanced Feature to select if you would like to generate "Little Endian" or "Big Endian" rpd file.
