APrab8
6 years agoEPCS16 device connected to a 10 pin programmer header in active serial as MTD device.
Hi Forum, I have an EPCS16 device connected to a 10 pin programming header from a raspberry pi. My target is to program a .pof file using active serial configuration to the EPCS16 device. what I ...
APrab8
6 years agoHi John,
You are correct we are implementing an SPI protocol. Thanks for suggesting to use raw binary file for this which I will do. can you let me know what tool should i use to convert the pof file to RPD ?
can you also confirm that the m25p80 driver in linux should work with EPCS16 device if yes can you please let me know what should value should i fill in compatible filed while generating the DTB ?
