APrab8
6 years agoEPCS16 device connected to a 10 pin programmer header in active serial as MTD device.
Hi Forum, I have an EPCS16 device connected to a 10 pin programming header from a raspberry pi. My target is to program a .pof file using active serial configuration to the EPCS16 device. what I ...
JohnT_Altera
6 years agoHi,
May I know if you are implementing SPI protocol into the Raspberry Pi? If yes, I would recommend you to generate RPD file which is a raw binary file. You may use this file to directly write into the flash.
