11 years agoEPCS128N issue unexpected erased
We have manufactured more than 70 units of a board that uses a CIV and a EPCS128M memory during the last 5 years. The boards are working without any problem. In the last fabrication of 25 units, some...
11 years agoIt looks like a bad batch. You should contact your supplier.
Just to be sure, after you got a board to work again, did you try and solder back one of the supposedly defective EPCS chips and did you reproduce the problem? Just to be sure it wasn't a soldering problem that you just solved by a manual soldering operation.
