14 years agoEPCS flashing
I have a BeMicro-SDK. It has a EPCS16 on board. I can configure the FPGA through the JTAG and it works until the computer goes to sleep or any power issue is encountered. This is expected with internal ram.
What I want. I want to be able to put a JIC file on the EPCS16 so I can get my custom configuration loaded at power up. What I have done. I found instructions here.http://sourceforge.net/apps/trac/welecw2000a/wiki/FPGAConfigFlash Results I can backup the initial flash chip configuration and testing showed it was good. I tried adding a file to the project with extension JIC. I am not sure if Quartus II should actually give it data by default or if something else needs done. After compiling the project I can program FPGA as before but Programmer fails on programming flash device. After Many tries I started the programmer up not through quartus. So only the add file part added any hardware. Checked program and it finally did flash the flash memory. Hope this helps others.No RepliesBe the first to reply
