16 years agoEPCS configure file format in AS mode
I have sevral questions about the EPCS' configuration file format. 1.If i want to update the configuation file,by AS configure mode,which file format is the appropriate? 2.About the right file ...
16 years agoif you mean to write the EPCS memory, the correct term should be program file not configuration file. if you are programming EPCS device thru AS mode it means you are using the .pof file right? modifying the content of the programming file will corrupt it and quartus programmer doesn't allow the corrupted file to be loaded.
