16 years agoEPCS configure file format in AS mode
I have sevral questions about the EPCS' configuration file format. 1.If i want to update the configuation file,by AS configure mode,which file format is the appropriate? 2.About the right file ...
16 years agowhat exactly do you mean by "update the configuration file" ?
files that contain the fpga image are created by the quartus software. modifying as you mentioned is not possible as far as i know. these files are not like binary files from microcontrolers where you can patch some kind of a string. you will need to change such messages, if they exist, within your fpga project source and recompile via quartus. but there is a possability to modify fpga memory content without recompiling if you have used some onchip memories and the are initialized by a MIF of HEX file. such onchip memories can be your application memory for the instructions as well as data or any other kind.
