11 years agoEpcq selection for arria v fpga
How to select epcq device as4 configtion for arria v fpga 5agxbb7d4f40i5 when design is not completed, which file to see .rbf or .pof for device.
11 years agoJust refer to the Arria V datasheet for the uncompressed .rbf size:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/arria-v/av_51002.pdf Then compare the .rbf size to the EPCQ size. The rule of thumb is that EPCQ device size > FPGA .rbf size. You can enable compression to compress the .rbf size to fit more images into the EPCQ.
