14 years ago
EP600 programming
I used some of these about 20 years ago. The need has arisen to modify a program (one which I didn't write) and program a handful of chips with the new code.
Can someone tell me if I'm on the right tracks?
I think I can use MAX PLUS+2 for this. Also a program called PLDshell (which I think I used to use). It seems these two programs are easily available. Even though PLD is a dos program (?).
I think there should be folks around who still have programmers supporting this chip. My first approach will be to find someone I can send chips and a file to.
If that fails, second approach will be to buy a used programmer. Does anybody here know which ones support the chip?
1 Reply
    MAXPLUS2 is capable of compiling for the EP610, but I'm not sure whether the EP600 is supported. I would recommend just downloading the software and seeing if the device is listed. If it is, you are half way there and will then need to find a way of programming the device.
    The original Altera MPU programmer and adapter head is long obsolete. Your best option would be to use a 3rd party programmer from someone like DataIO.
