14 years agoEP600 programming
I used some of these about 20 years ago. The need has arisen to modify a program (one which I didn't write) and program a handful of chips with the new code. Can someone tell me if I'm on the ...
14 years agoMAXPLUS2 is capable of compiling for the EP610, but I'm not sure whether the EP600 is supported. I would recommend just downloading the software and seeing if the device is listed. If it is, you are half way there and will then need to find a way of programming the device.
The original Altera MPU programmer and adapter head is long obsolete. Your best option would be to use a 3rd party programmer from someone like DataIO.
