EP4CGX22CF19C8N Failure Short D8 to C8
We encounter failure for EP4CGX22CF19C8N related to pin D8 to C8. Failure observed during turn on stage on system level. Further verification leading to EP4CGX22CF19C8N shorted related from pin D8 to C8. We conducted ABA swap and the issue resolve. Failure follows the bad part. Table below indicates measurement comparison between good unit and failed unit. Please advise what would be the caused for this issue?
| Condition | Reading (from U57.D8 to U58.C8) |
| Good Part | OL (Open Loop) |
| Bad Part | 2.1 Ohm |
- AqidAyman_Altera
Hi Syafril,
It depends on the device family. For Cyclone IV GX, it needs minimum three device affected with the same failure.
Refer here: Failure Analysis Support | Altera
Aqid
- AqidAyman_Altera
Can you identify how many units that was affected? What is the failure rate?
Aqid
- Syafril
We currently found 1 pcs affected and would like to know the cause of it.
- AqidAyman_Altera
Hi Syafril,
This need to be go through the Failure Analysis (FACR) to only know the cause of failure.
However, I apologies as we can't proceed with FACR if not reaching the minimum amount of failure units.
Aqid
