18 years agoEP3S150ES VCC/VCCL Resistance to ground
Hi All: We just got a board back, and we are seeing an oddity on the 1.1V supply. We haven't powered the board yet, because of this. Right now we are seeing ~3-4 Ohm resistance to gro...
12 years agoAre you sure all power supplies to the FPGA are up? There are several that will keep the device in power on reset. if they are not up all the way.
there's also a note on the ramp time of VCCPD and VCCPGM: --- Quote Start --- VCCPGM and VCCPD must ramp up from 0 V to the desired voltage level within 100 ms. If these supplies are not ramped up within this specified time, your Stratix III device will not configure successfully. If your system does not allow ramp-up time of 100 ms or less, you must hold nCONFIG low until all power supplies are stable. --- Quote End --- When you are trying to configure it via active serial, are you seeing any activity on the DCLK, DATA0 and CS pins? Pete
